meshpoint
      Creates a new meshpoint and enters its
         configuration mode. Use this command to select and configure existing meshpoints.
Meshpoint configuration is not supported
            on 802.11ax access points. This feature will be supported in future
         releases.
Supported in the following
            platforms:
            - Access Points —
               AP7612, AP7632, AP7662, AP8533
Syntax
         meshpoint [<MESHPOINT-NAME>|containing <WORD>]
      Parameters
                     | <MESHPOINT-NAME> | Specify the meshpoint name. If the meshpoint does not exist, it is
                        created. |
                     | containing <WORD> | Selects existing meshpoints containing the sub-string <WORD> in
                        their names |
         nx9500-6C8809(config)#meshpoint testMeshpoint
nx9500-6C8809(config-meshpoint-testMeshpoint)#?
Mesh Point Mode commands:
  allowed-vlans  Set the allowed VLANs
  beacon-format  The beacon format of this meshpoint
  control-vlan   VLAN for meshpoint control traffic
  data-rates     Specify the 802.11 rates to be supported on this meshpoint
  description    Configure a description of the usage of this meshpoint
  force          Force suboptimal paths
  meshid         Configure the Service Set Identifier for this meshpoint
  neighbor       Configure neighbor specific parameters
  no             Negate a command or set its defaults
  root           Set this meshpoint as root
  security-mode  The security mode of this meshpoint
  shutdown       Shutdown this meshpoint
  use            Set setting to use
  wpa2           Modify ccmp wpa2 related parameters
  clrscr         Clears the display screen
  commit         Commit all changes made in this session
  do             Run commands from Exec mode
  end            End current mode and change to EXEC mode
  exit           End current mode and down to previous mode
  help           Description of the interactive help system
  revert         Revert changes
  service        Service Commands
  show           Show running system information
  write          Write running configuration to memory or terminal
      Related Commands
                     | no | Removes an existing meshpoint |
